Analytical connections for sanitary equipment.
Analytical connections are available for hydraulic connections of HVAC equipment (perfect), but not for sanitary equipment. It would be very practical to install them (at least for water supplies).
3 Comments
adbryson
This needs to be an option for not just the Mechanical Equipment category of elements, but should also be made available for Plumbing Fixtures.  Please and Thank you!
paul.disney
Any family that has a pipe connection and can communicate a flow or demand a flow from a system should have Analytical Connections available to use.  Plumbing walls can have a lot of pipework in them, so it oftentimes does not make for a clear and concise design drawing if we have to draw every pipe to every fixture in order to calculate Fixture Units.
jkarben
Please make them available for duct accessories too, such as duct mounted coils. Any pipe connector should have the option to have an analytical connector. Much more than just Mechanical Equipment as is atm.
