Analytical Automation
It would be nice to have the option when using the Analytical Automation from either Physical to Analytical or Analytical to Physical to be able to choose top of steel for beams. Because to nearest level does not always work as well as can be seen from the screenshot. If we don't choose to nearest level the analytical lines goes through the centroid, but then you have the problem where different size beams centroids causes offsets.
