Allowing scale in sheets schedule
I don't understand why i can't list automatic scales in Sheet List, where that option exist in my Titlebox? I need to know if my sheets contains "As indicated" value or just normal Scale and it's impossible to check it in other way than manual check on each sheet.
9 Comments
mhiserZFHXS
I've never understood why this is necessary. A list of view scales means nothing without the views themselves. Just include it in the viewport for each view.
s_brzeskaVW4T2
In all Teams i was we changed automatic scale when it was "as indicated" to manual scale, because we had different legend scale and layuot scale, od different drafting view scale. If you use office template it's impossible to make same scale everytime on sheet. I work with architecture and interior.
mhiserZFHXS
I see what you're saying now. Why not just add the scale to your viewport title, then you don't have to worry about all that?
Or if you're dead set on keeping it in the titleblock, create a view list schedule, and include the fields for sheet number and view scale. Sort it by sheet number so views on the same sheet are grouped together. Then you can see which sheets have multiple scales on them.
s_brzeskaVW4T2
Im doing this, sort of. But this would be so much easier.
mhiserZFHXS
How? Its the same process. Its just a view list instead of a sheet list.
s_brzeskaVW4T2
But i need more information from sheets to compare
mhiserZFHXS
Like what?
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
 -The Factory
Help | Sheet List Schedules Enhancements | Autodesk
