Allow undo/removal of Modify Returns for Wall Sweeps
After modifying an integral sweep return on a wall, it is sometimes necessary to remove the modified return at some point later in the project. Currently there isn't a native way to do this. You can change the wall to a type without sweeps and then back to the original wall type, but any dimension or tag references to the sweeps is lost in this process.
2 Comments
rsnyderPNHQ9
If you have a Return already, you can remove the Return by selecting Modify Returns and then Straight Cut from the Return Options.
Then pick the end of the Return
And it removes the Return
It's explained in the second part of (5.) here:
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-D3E54426-2820-44EE-9E29-77922F505E11
BethEvanoo
Thank you @rsnyderPNHQ9 !
Just goes to show you always need to look through those radio button/check boxes. I wonder if they slipped that in at some point in the last ten years after I stopped looking for it, or if I just missed it from the start.  😄
