You have a linked file that contains nested links. You would like to control your visibility from this linked file and attach it to the host using "By link View". However, when you have tried to closed some of the worksets from "Manage Worksets" from the link file, you can see the worksets closed from the host.
Worksets are not read in nested link(s) in the same manner they are for top-level link(s).
Above is quoted verbatim from https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
I would like to be able to, optionally, specify that when I close a workset for a link that all qorksets with the same name that appear in nested links should also be closed. This would very very useful to globally control visibility of shared levels and grids and other elements that are placed on their own worksets.
Workarounds listed in the above cited page are unacceptable. Why do we have so many workarounds? Please fix some of these issues. I'm not in the habit of complaining too much or comparing Revit to other products, but every time Archicad releases a new version I weep quietly on the inside. We are getting left soooo far behind in terms of what is possible and implemented by other BIM solutions, and Archicad in particular. Please, please, please take a look at some of the workflow that others are implementing and take current requests for features and fixes more seriously. I'm sure you're plenty serious but somehow that does not translate well into reality. Please. You're awesome. You can do it!
