Allow the same Revision Number for multiple numbering sequences
Revit 2022 introduces the ability to create additional numbering sequences.  This is great, and something we have needed for a long time.  Unfortunately, it does not enable me to have multiple numbering sequences with the same number.  We often use a single project for multiple small packages, or have early release packages.  Each package has its own sequence of revisions, and each sequence needs to start with a revision number of "1".  However, doing so creates an error that cannot be ignored.
The revision sequence number is always unique, so it should not matter if I choose to have the same revision number on multiple sequences.  I can fake the desired result with a whitespace suffix character, but that is not desirable, nor is it efficient over multiple packages or when coordinating with consultants.  I don't mind a warning, but it should be treated like any other duplicate mark warning, where it can be acknowledged and ignored.
3 Comments
kimberly.fuhrman
Hi, @jkidder ,
Here is a similar Idea...do you think we should combine yours with this one?
Allow duplicate Revision Numbers - Autodesk Community
Thank you for your submission!
-Kimberly
jkidder
@kimberly.fuhrman It is similar, but mine directly addresses the 2022 updates and what they do allow/ do not allow. The previous idea did discuss revision sets, which is something that 2022 takes care of.  It is only the duplicate numbering that is still not possible.   I think as long as that it is clear that the issue still remains even with the 2022 updates it would be ok to combine them.
kimberly.fuhrman
@jkidder  Thank you for the additional clarification! I will leave it as is.
-Kimberly
Forma Design Contest
Technology Administrators
