Currently in schedules parameters of type "Material" and "Family Type" only display the name. Once added to a schedule those parameters should be able to be selected in the the format tab and the "Field Format" selected. There other parameters for the material/family that are scheduled could be selected. This would allow greater flexibility in schedules and reduce the number of redundant, dumb text parameters needed to convey information. Ideally this would work for tags too (replace the modify units button with a field format, doing both unit adjustment and parameter selection).
Examples:
- A door schedule needs to show the material description. By default when added to the schedule the material name "08-Door Frame-Hollow Metal" is displayed. Clicking on field format brings up a list of available material parameters. Select "Description" (or "Material: Description" to be consistent) and the field would then display the material description of "HM" instead of the material name.
- A door schedule needs to show the frame type. The frame is a nested family. By default when added to schedule the Frame Type (Family Type: Doors) parameter displays the family name of "08-Frame-HM-F1". Clicking on the field format brings up a list of available parameters to door families. Select "Type Mark" and the field would then display the chosen door's type mark of "F1" instead of the material name. If the frame type is changed to F2 the cell would update correctly. If the type mark is changed to F01 it would update.
An alternate, and probably easier way, to implement this request: Parent family to read and report nested family type parameters
