Allow Project/Shared Parameters to be assigned tovObject Style Subcategories
Currently, a parameter - project or shared - can only be assigned to the primary categories hard coded into Revit. But categories such as mechanical equipment include a wide range of equipment types, such as pumps, air handling units, fans, blowers, process equipment, etc.
We would like to expand on the object style's ability to have subcategories defined under a category, and allow parameters to be assigned to specific subcategories. This will dramatically reduce the instance and type parameters that appear on an object in one of the categories that are displayed on the properties palette, and allow for the association to be more clearly defined.
Autodesk Customer Advisory Groups
