Keynotes of the Material and Element type should allow multiple leader lines. Right now if I only want to annotate GWB (as an example) once on wall sections, details, or elevations, I must add a text object with a period then add leaders from it pointing to the additional instances.
There's no reason I should have to place this blank leader or two separate GWB notes on a section/ elevation/ detail if the material occurs more than once. A leader from
For review/ accuracy If the leader touches multiple materials/ elements it would return a "?" the same as a tag touching an undefined item.
