cancelar
Mostrando los resultados de
Quiere decir:
Allow door host to be tabbed to even if not visible
Currently, if a door's host wall is not visible in a plan, it cannot be tabbed to in order to be selected. If any portion of the wall is visible, it can be selected by tabbing on the door. In the example below (this is all a family, not a curtain system), the door is hosted in a wall that runs perpendicular to the other walls showing, but since the door's frame runs from wall to wall, the host wall is not visible and therefore cannot be selected. This provides a minor but still annoying inconvenience when trying to adjust a doors positioning while in plan.
It would be helpful if tabbing over the door would cycle through to the host wall, allowing it to be modified.
2 Comentarios
Mark_Engwirda
Absolutely @mhiserZFHXS  and the same would apply for windows etc or any other hosted object ?
mhiserZFHXS
@Mark_EngwirdaSure. Its not usually an issue with other objects though, as you can see the wall adjacent or underneath them. But yea, just in general, allow tabbing on a hosted object to cycle to its host regardless of if its visible or not.
Enviar idea
