cancelar
Mostrando los resultados deĀ
MostrarĀ Ā soloĀ  | Buscar en lugar deĀ
Quiere decir:Ā
Allow all things to schedule what room they are in
When creating schedules, most thing are unable to schedule what room they are located in.
For instance, a ceiling schedule can't tell you what room the ceilings are located in.
Without this ability a ceiling schedule is fairly useless.
Revit should be able to tell you what room anything is located within (or state 'Multiple' if its in multiple rooms).
Thanks.
3 Comentarios
wr.marshall
Just a query regarding this: If I was designing a block of flats/apartments and 2 flats/apartments are exactly the same layout but on different levels how would you differentiate between these levels
Maybe something like L2-Apt201-Bed 2 ceiling = 3m.sq and L3-Apt301-Bed 2 ceiling - 3m.sq...
Format for however this is accomplished will need to be customizable as each project/comany/contractor will have there own requirements to determine this. But will further BIMify geometry.
Voted for anyhow as think its a good idea
Excelente ideia! obrigado pelo envio @Kevin.Bell
wr.marshall
@Kevin.Bell probably a bit long winded , but will do the job required if you create and assign project parameters to break down elements as required.
Enviar idea
