All Callout Types should have Show in Parameter
Callouts (regardless of if they are detail view type, section type, elevation type, or plan type) should have the option to appear in intersecting views same as the detail views do using the "Show in" parameter.
There are some features of the section type, elevation type, and plan type callouts that are not available in the detail view types (e.g. Depth Cueing in section or elevation type callouts and View Range in plan type callouts).
Along with the "Show in" parameter should go it's companion parameter "Hide at scales coarser than" parameter.
Similar, but more specific ideas that should also be voted for or perhaps combined with this one:
https://forums.autodesk.com/t5/revit-ideas/view-range-control-in-callouts/idi-p/9115445
https://forums.autodesk.com/t5/revit-ideas/callout-in-multiple-views/idi-p/7150030
