Align/Snap Text and Annotation
Please, for the sake of our sanity let us align/snap text, dimensions, leaders, annotation and all of the other things that we currently cant align/snap
13 Comments
EmptySaturnV
It would be nice to have the ability to align multiple text objects at one shot versus having to drag each individual text item one by one to line up correctly. Similar to the "align multileaders" command that exists in autocad.
When copy paste a detail which needs rotating or mirrored you have to pick individual text to then re-align. Can we have a button which does them all in one go or even better just keeps the alignment automatically when mirrored.
Tags (1)
Orsolya.Balazs
Autodesk Support
On behalf of a customer from Germany let me submit the following wish: feature for aligning text to any lines/ frames.
Currently it is possible to rotate the texts, but a step quicker would be if it would be allowed to use the align command for texts as well.
Tags (2)
Great idea!
*Not part of the Revit vainilla but you can use pyRevit's (free) extension pyRevitPlus, which has distribution and alignment tools for most types of Revit elements.
http://eirannejad.github.io/pyRevit/
A_MAQ
ability to align all text either to right or left to be at the same alignment likewise in dynamo will be great feature
A_MAQ
does that possible ?
bjoern_teutriene
This improvement would be very important for German Revit users. In the Revit Wishlist 2017 in Germany it ranked #5 out of 52 wishes. You can find more information on https://www.rug-dach.de/
rudermann
If text is justified by left - center - right, why can't we use the align tool. I sometimes have differing sizes of text that I would like to align. The align tool could grab and align bottom and top (with a default spacing) and start, middle or end of text to align.
rudermann
Another thought on text...
When you click on text you get shown a bounding box. I would like an option to make the bounding box a line detail.
creed
Text boxes & labels should have nodes at the corners & midpoints of the boxes (like in AutoCAD) to control their alignment & length.  These should be able to be aligned/locked to reference planes so that text box length in things like view titles or room tags can be controlled without having to create entirely separate types.
In addition to this, if one could align detail elements to labels, one could create a tag that auto-adjusts based on its length.
jackie.watson
The Revit experience designers are looking into these types of improvements. Please reach out to me if you would like to contribute to usability studies where you may provide feedback to proposed design solutions and add your own ideas.
Jackie Watson
Principal Experience Designer, Revit
jackie.watson@autodesk.com
Gary_J_Orr
All of the comments in this thread are spot on.
Our industry (AEC) relies on readability and precision. To enable these things our old tried and true AutoCad kept a focus on giving us precise control of everything.
Text had nodes to snap to. You could dimension to them, you could align by them, you could set width of wrapping text with a width parameter to keep them all the same... you had control.
Revit is drag this, and drag that, and, oh, that's close enough... But all of the information is there, so why not just let us see it and use it?
-G
