Advance Steel Standard vs Oversize automatic holes
This could be considered an AutoCAD issue as well as a Revit issue as it pertains to "Advance Steel".
There is no way to set the diameter of the holes automatically placed in the steel member when placing a bolt or connection with bolt.  The hole is always the standard size.  This is unacceptable!
Many connections require joints using "Oversize" holes.
These holes are standard sizes as well.  Advance Steel should insert and option, anytime a bolt is used, to use a "Standard" or "Oversized" hole.
Technology Administrators
