Advance Steel Plug In - Steel Connections - Match Properties
In REVIT, using the Advance Steel Plug In - Steel Connections, it is not possible to transfer parameters (properties) between steel connections (Match Properties). Could this functionality please be added to REVIT.
3 possible solutions:
Within AUTOCAD Advance steel - xfer of parameters is possible by:
1. Joint Copy
2. Joint Properties - Save in Library for future reuse on a different connection
(see attached PDF)
OR add this functionality to REVIT by
3. Match Properties - currently doesn't work for Steel Connection parameters
Hope this all makes sense !
Cheers
Howard L'
Forma Design Contest
