cancelar
Mostrando los resultados de
Quiere decir:
Addition of a Roof floor plan
Problem:
I am a mechanical engineer and I use Revit MEP for HVAC system design. We often have equipment on the roof such as condensers or dx coils and to show them we make a roof plan. However, most roofs are pitched and because of this the view range of the roof plan has to extend from the top of the roof to the bottom edge of the roof in order to show all of our equipment on the roof. This results in items (like walls, piping, electric, mechanical equipment, etc...) underneath the roof being shown.  What we currently have to do is drop the view range so we can see all of our rooftop equipment and then hide anything that we don't want to see which can be view time consuming. This issue happens in all disciplines and not just mechanical as well.
Solution:
Some kind of a floor plan or a setting that doesn't look below the roof. The view range can be built such that when the bottom of the view range touches a roof element it does not go any farther. The view can still be set up like a normal plan view meaning it has an associated level and view range.
3 Comentarios
No aplicable
This would be useful for structural as well.  It is impossible to dimension roof beams correctly in a normal plan view.   I have made section views in the past but it isn't the best.
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
El estado se ha cambiado a: Archived
Enviar idea
