Adding Custom Scale for Line Weights
I would like to have the ability to set custom scale for line weights. For example now if I have a plan which has a costume scale of 1/150, I can not manage my line weights in this scale. In the manage, Line weight setting you can just add the default scales and edit them.
7 Comments
filipefrancisco
I Agree...
italonge
 So is not there a way to solve this?
e.filippova
Observer
 very important feature
465340553
这个功能还是很有必要实现的。
karina.honda
if there is no way to set that Autodesk must pay attention to this topic for the next updates.
douglas.taguchi
up
Ric_Weber
Scales in-between the built-in scales will be controlled by the lower valued scale factor.  So line weights in the 1:150 scale will be controlled by the same line weight values as 1:100.  All scales from 1:100 to 1:199 will have the same line weight as the 1:100 items.  If you need the line weights to be different between 1:100 vs. 1:150, then I agree you need this feature.  I only have scales set in my line weights. From 1:1 to 1:95 is one set of line thicknesses, then 1:96 to 1:191 is another, then 192 and up is a third thickness.  (we're in imperial, so that's why the strange numbers).
