Add some area to room total area
1)
What about if I want add to room area also door threshold area.
My idea is in attachment.
(MY IDEA - when the room boundary cross the other room separator line ...revit automaticaly calculate add this line)
some developers need also add sill area...when is sill height 0. Why don't use same method ..add separator line to window family?
2)
why revit can't add are area when is wall in wall used cut function?
Revit add the niche when is the have the center line of inserted wall before the center line main wall.....when is the wall behing main center line revit not add this area.
3)
Why is the separator lines so unusable.....moving and snap is hard.
4 Comments
jkidder
It sounds like your first two ideas are a mix of these two previous requests: Ability to define room bounding elements in families and Net and gross sf of room.
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
I think this might solve your issues- if you agree please share and vote for it!
Rules per view for calculating ROOM Areas
https://forums.autodesk.com/t5/revit-ideas/rules-per-view-for-calculating-room-areas/idi-p/11464439
