I export Revit sheets to Autocad (as per client request), but all the sheets are exported as Autocad layouts on the same paper size (the default printer and default paper size, e.g letter or A4). We need the option to choose what printer and what paper size we need, as sheets' size may vary a lot. Yes, i am willing to export each sheet individually IF i have the option to choose the paper size.
When i export to pdf i use the ProSheets extension and every single sheet gets the right paper size, but exporting to dwg doesn't seem to work the same way.
I have to (re)create every single layout paper size and ctb plot style.
It would be very helpful if Revit could use the DWG to PDF.pc3 configuration file, so we could choose paper size and share custom paper sizes with Autocad.
