Add Hatch & symbol parameters to Schedule
I still have to just have the finish legends be text because neither the height of rows can be changed nor hatches added to the schedule, which could automatically space the rows at the least.
Hatches should be able to be a parameter and added to schedules.
While we're at it should be able to add a symbol parameter.
3 Comments
awasyliw
This could be useful. It'd also be useful to be able to add a material swatch as well as a pattern.
By the way there is a workaround, you can create a jpeg of the hatch in your revit file and then bring that in to a schedule using the image parameter. https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2019/...
Actually we should be able to add any of the views for any element that can be seen as a legend component too, instead of having to create an image of it first (and the options for legend components needs upgrading too - https://forums.autodesk.com/t5/revit-ideas/upgrade-legend-components/idi-p/8291452 ).
colinqBYUV9
I knew this must have been suggested before now. Also, very surprised the idea hasn't received more support. This would make schedules so much better.
flopezEseMero
Que no solo sean hatch, también la posibilidad que pueda asociarse a una vista (planta, sección, elevación) y obtener los hatch con su respectivo filtro gráfico
