cancelar
Mostrando los resultados de
Quiere decir:
Add File Name Parameter to Filter rules list in Revit
I would like to introduce the idea of adding the File Name Parameter to the list of available parameters while creating Rule-based Filter in Revit.
Currently, it's not possible to create a filter for objects coming from a specific linked file. Having the possibility to specify the File Name, only elements from specific link(s) could be overridden/hidden using the filter.
2 Comentarios
Reed_Weinstock
One thing you can do is filter by workset which can help achieve a similar result.
Good idea, I actually think this should be consistent with schedule filtering where you can select the Revit link, material, room, etc.
Enviar idea
