La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Could you expand on the properties that the asset would need and the use cases for the asset? Also, how would you expect to see the asset and its properties exposed in the interface?
Properties would be the STC (sound transfer coefficient) of the material. Add that to the STC of other materials and we'd have an STC for a wall for instance. Also, it hopefully could be something that could reported in a schedule that way as well. The asset would just be the starting point of being able to do all of that. I'm not sure what you mean by your last question. It would just look like any other assets. It would be a tab. I'm sure that an acoustical engineer could tell you all the parameters that would really make it up. But that's the basics of what I'm looking for. Thank you.
