Ability to turn OFF/ON "Grand Totals" by parameter, not just across the schedule (by activating Calc Totals)
Many times schedules need the "calculate total" to be turned ON, so that line by line we do not get the <varies> value.
This does not necessarily means that we need the Grand total, at the end of the schedule.
In these cases, we have to mask these unwanted grand totals on a sheet.
See example attached:
And where this new option could be located:
1 Comment
Mike.FORM
You can turn off the grand totals for specific parameters by changing the dropdown to "no calculation".
Something they should do though is make percentages that have grand totals turned on work by calculating the value from the grand totals of the parameters they are using in the formula and not sum the percentages in the column.
