This is an important enhancement request. It seems like a really simple idea.
FEATURE REQUEST:
- The ability to change the keynote number for user created keynotes.
Currently:
- Keynotes number themselves per sheet (when that option selected) based on the CHRONOLOGICAL ORDER in which they were placed. This would be similar to the way views initially number themselves when you place them on sheets. Gridlines also perform this way.
- Sometimes you add a new item to model and want the keynotes associated with it to be numbered / grouped closely together in a logical sequence. This is not possible. Any new keynote will go at the bottom of the current keynote list.
Request:
- The ability to manually change the numbering of user created keynotes on a sheet
- This features is available for viewports (you can renumber your views if you move them around or delete and replace a view with another).
- This feature is available for gridlines (you can change the # / letter of your gridlines when you move them around or add new gridlines in between).
This would be very useful. THANKS.
