Ability to edit existing parameters "tool tips"
Please enable the ability to edit existing parameter tool tips (in family or shared parameters files).
This shouldn't cause that much grief as it doesn't influence the parameters performance and would save us a fair amount of time updating misspellings or the lack of tool tips.
The current workaround forces us to make a dummy parameter to swap the existing parameter name we want to keep,  deleting the parameter from shared (if you want to re-use its name), create the previous parameter with tool tip and then swap the created parameter with the dummy parameter (to avoid formulae re work).
OR
Swap the old parameter with a new shared parameter with tool tip
Neither are preferred for a simple mod like that
