Ability to add a texture image to 'shading appearance'
If you could add a texture to the shaded appearance it would be you could do illustrative plans etc. at the moment we export the plan and the interiors do add textures to the plan.
If this was added you could alternate between
Technical Hatching
Illustrative Shading
Rendered Material
1 Comment
pieter4
Big +1. Although there are already two ideas out there about this. Consider adding your votes there as well (and perhaps leave a comment or link to this idea).
https://forums.autodesk.com/t5/revit-ideas/correct-colors/idi-p/7711993
https://forums.autodesk.com/t5/revit-ideas/consistent-colors-mode-with-textures/idi-p/7931742
Forma Design Contest
Technology Administrators
