The ability to see project base points and survey points from linked models is great. But when you need to custom override the model elements in linked model, you need to make sure people are switching off the PBP and SP at the same time as what they are intending to override. (which they don't)
If it could be possible to put these into a workset (so we could control these globally at Manage Links)
Or some other way to turn them off globally that
- biggest issue is when you upgrade a model and have to retrospectively have these turned off in all templates!
