We need the most commonly used corner mullion condition that occurs in buildings which is a mullion that is angled at the corner. This mullion will be set at 45 degrees to the corner at a 90 degree outside corner and at 135 degrees to the corner at 90 degree inside corner. This mullion should be adaptable to other wall corner angles. Please see attached image.
