We are implementing the A360 Team in a big BIM project and we have the following problem with published views:
- When we upload the models through A360 Colaboration for Revit so our client can view a central model (composed by linked models which are also in the A360 Team)
, we cannot see the central model with the linked models, when reviewing the published views are not associated with links and only the elements housed in the same revit.
It is very important for us to show our big clients that the A360 C4R and A360 Team really provides a good solution for on line collaboration and clear visibility or the central model with linked models.
Hello and sorry to hear you are having issues. Do I understand correctly then that when you publish the central model shows ok, but the links are not coming through in the publish? Or is nothing showing up on the BIM 360 Team side of things?
A couple other questions would be do any of the links show? What version of Revit and C4R are you using? Would you be willing to private message a link to the model so I can see the behavior?
thanks,
