Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
You currently don't have access to Revit cloud models
23 REPLIES 23
Message 1 of 24
mohamed.yasser2311
1418 Views, 23 Replies
Hello Dears,
"When I open Revit 2023 and want to access cloud, the image window appears every time. I have tried the same account on another machine with version 2023, and the cloud files appear without any issues.
When I use the same account on my machine (which has a problem with 2023) with anthore version (revit 2020 or 2021), the cloud works without any problem. It works with 2020 and 2021, but only has this problem with 2023.
Can anyone help me solve this?"
23 REPLIES 23
Message 2 of 24
jade.l
in reply to: mohamed.yasser2311
Hi @mohamed.yasser2311
As you can work with R2023 with another machine and R2021 and R2022 work well, my best guess is something wrong with the R2023 installation.
Can you please message me a 23 journal so that I can take a look?
BTW, can you try out if you can save a local model to cloud with "save as cloud model" in the problematic 23?
jade.l
Message 3 of 24
I am having the same issue with Revit 2021 and 2022. Just started this week. I have already did the steps from the following Autodesk Support. Nothing works.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Projects-via-BIM36...
https://support.a2ktechnologies.com.au/hc/en-au/articles/360003864236-You-currently-don-t-have-acces...
Message 4 of 24
jade.l
in reply to: Steven-BaxterBIM
Hello @Steven-BaxterBIM
Sorry about the experience. Can you please message me your journal?
jade.l
Message 5 of 24
Steven-BaxterBIM
in reply to: jade.l
Here are the latest journals.
Message 6 of 24
jade.l
Hi @Steven-BaxterBIM
do you attach the journal or send me a private message? I don't see it.
jade.l
Message 7 of 24
Steven-BaxterBIM
in reply to: jade.l
Txt. and Log attached
Message 8 of 24
jade.l
The Revit config file is not downloaded successfully so it blocks the cloud model workflow.
 Start to get Revit config from service https://rvtcfg.autodesk.com/155b01e6d2/config.json.
' 0:< Fail to download revit config from service: Exception Object reference not set to an instance of an object.
' 0:< Revit Configuration is null.
' 0:< Failed to execute GetRegionFromRevitConfiguration, return null.
But I don't have any idea why it is blocked recently as you mentioned that you can work before.
Something to try:
jade.l
Message 9 of 24
Steven-BaxterBIM
in reply to: jade.l
I have tried turning off the firewall but still had the issue.
When i open you link it looks like this:
Message 10 of 24
jade.l
Thanks for the reply @Steven-BaxterBIM
Firewall and Anti-virus software could be something different.
another thing to try is run Revit as administrator.
jade.l
Message 11 of 24
mohamed.yasser2311
in reply to: jade.l
Thank you @jade.l
I traying to save model as central file on cloud but save (In Cloud) not active as shown in photo
For Journal files, I have many txt journal files and i didn't know which to sent.
Message 12 of 24
I Also try this solution but nothing work
Message 13 of 24
jade.l
@mohamed.yasser2311 you can send me the latest one that you tried to save a cloud central model.
jade.l
Message 14 of 24
mohamed.yasser2311
in reply to: jade.l
Thanks @jade.l
Also this message in the following photo is appeared when I tray to save model as a cloud
You can also find journal files in attachments.
Message 15 of 24
@jade.l
Message 16 of 24
jade.l
Sorry for delayed reply. @mohamed.yasser2311
From your attached journal, the revit config is not downloaded successfully either.
I can't tell what blocks the download.
jade.l
Message 17 of 24
jade.l
@Steven-BaxterBIM @mohamed.yasser2311
I think we need to do further trouble shooting to solve this issue in your environment.
Can you please submit a support ticket to get help accordingly?
https://www.autodesk.com/support/contact-support
jade.l
Message 18 of 24
jade.l
Not sure how is going with your problem.  We've got several support tickets about this recently.
One workaround is to use another network (for example, mobile hotspot ) to launch Revit. It works.
Some reports say it works when switch back to the original network.
We are still investigating the reason behind.
jade.l
Message 19 of 24
I have struggled with this same issue for the last two weeks.  I am not certain what changed but it affected all three machines in our office, the only thing that worked was to uninstall "Desktop Connector" and re-install.  I installed the latest build 16.2 and it functions correctly now.  Hope this helps.
Message 20 of 24
Hi, Guys, there is something you are worthy to try if the case is cannot download Revit cloud config file:
C:\curl\bin>curl.exe -v https://rvtcfg.autodesk.com/155b01e6d2/config.json
*   Trying [2600:9000:2464:ca00:4:5294:5700:93a1]:443...
*   Trying 18.161.156.46:443...
* Connected to rvtcfg.autodesk.com (18.161.156.46) port 443 (#0)
