Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Worksharing offline with Collaborate Pro
5 REPLIES 5
esatis
214 Views, 5 Replies
is it possible to work on Revit local model through Collaborate Pro Worksharing when offline ?
For example- we use Collaborate Pro Worksharing and one user is offline for soke days.
Will he be able to continue to work on his local copy of the model ?
I cannot find any information on this topic in Collaborate Pro Help.
5 REPLIES 5
RSomppi1
in reply to: esatis
They can work on it but it will most likely become incompatible with the central model if certain precautions are not taken and strictly adhered to.
sureshchotrani
in reply to: esatis
Currently not supported, you need to be online.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
RSomppi1
in reply to: sureshchotrani
Negative.
esatis
in reply to: RSomppi1
thank you, are these the precautions you mention: https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-4E002119-F780-4DFB-AC24-11EF005094D3 ?
RSomppi1
in reply to: esatis
Yes.
Plus, ALL parties working on the model NEED to be fully aware.
Proceed with EXTREME caution if you are going to attempt this. Have back-up plans in place.
