Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Worksets
3 REPLIES 3
303 Views, 3 Replies
Worksets
HI!,I have tried to work in collaboration but the worksets button is disabled.Smiley Sad
Tags (2)
3 REPLIES 3
If your workset button is disabled, this is probably because you are not currently working on a central project.
To define your project as central, you have to go to the Collaboration button in the ribbon of Revit.
After that, you have to choose a location for you central file (on a server for example or directly in your A360 storage).
When you did that, the button workset should be available.
I hope this will help you.
kadmonkee
do you have the latest version of Revit with the C4R "Collaboration 4 Revit" plug installed?
are you actually logged into a BIM 360 TEAM hub?
does you r collaboration Tab on the ribbon look like this
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
konghoang
in reply to: kadmonkee
I also had the same problem.  The workset button was working fine, but suddenly it stopped working / disappeared.    Issue was plugging into HDMI and USBC for 2nd screen which was hiding the workset window.  Lesson learnt only plug into USBC or HDMI for second screen.
Technology Administrators
