Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Which to chose? - Revit Server vs Cloud Worksharing
2 REPLIES 2
markdavies_PRark
347 Views, 2 Replies
We are shortly starting a collaboration with another architecture studio and need to set up Revit work-sharing between the two (small) offices in same city.  We both only use file-based LAN worksharing now.
The other office has previously used Server (back in 2015 I think) but doesn't have in house knowledge on setting up / use (bosses just assumed it can be done).  I have no experience with Revit Server or Revit Cloud Worksharing.  And obviously I have to get something setup next week...
Should we go straight to the Cloud solution?
Can anyone point to some resources on pros/cons on each? Any advice gratefully received!
2 REPLIES 2
CloudWorksharing for sure especially when you have no IT department
Hi @markdavies_PRark I agree with @MichaelRuehr that you should opt for the Cloud-based work sharing.
Check out this article
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-090ECB0C-55AE-4F2B-BC82-94B587F9FDC2
Another discussion on the same: https://www.reddit.com/r/Revit/comments/jjnpu2/filebased_worksharing_vs_serverbased_worksharing/
If this solves your problem, please mark it as a solution so that others can locate it. Thank you.
Symetri Logo
Prateek Chitnis
Strategic Implementation Manager | AECO (Buildings)
facebooktwitterInstagrampm
