Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
view linked model other file
1 REPLY 1
jmendezicce
303 Views, 1 Reply
hi
i want to see a revit link in other file, for example, i have 3 file
1 file contain 1 building other file contain other building and other file contain only revit building 1 and 2 linked
i need create other file with just 1 linked file(contain 2 revit link) and view these links
i hope explainme well
thank a lot
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
Si esto ayudó a resolver su problema, recuerde "aceptar como solución" para ayudar a otros a encontrar respuestas.
1 REPLY 1
laurasmagin
in reply to: jmendezicce
To achieve what you desire, you'll need to ensure the links in the file which you will push forward into another link has the links as attached.
If they are set to overlay they will be omitted when the file is linked into another file, if the files are attached they are retained when the file is nested.
Hope this helps.
Give me Kudos or mark as a solution if this helps
Regards
Laura
