Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Using A360 collaborating on central file but offices in different countries
1 REPLY 1
GAADesignLtd
309 Views, 1 Reply
Hi
I have an office in India and one in the UK. At present the India office does work on separate files and just sends it over. We do have larger projects that need central files so we have a remote desktop setup at present to get around this. I wanted to know how well A360 works for this set up instead? It would be great if I can have the central model in A360 and then both offices as well as the structural and M&E engineers can collaborate via this.
Any help in how this has worked (or not) would be appreciated. Thanks
1 REPLY 1
Wellcome to the community:)
It works great when you are working in a different location on the globe.
You will require C4R, kindly have a look at http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2016/collaboration-for-revit/ar1767... for more information.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
