Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Upgrade from 'Autodesk Revit 2016 (Pre-release)' to 'Autodesk Revit 2016'
3 REPLIES 3
john.higgins
380 Views, 3 Replies
Hi Guys
I was opening a central file and also auditing the file and I got a pop up window telling me my file was being upgraded from 'Autodesk Revit 2016 (Pre-release)' to 'Autodesk Revit 2016'. This only happens when auditing the model. Anyone know what the implications are of such an upgrade regarding linked files from other consultants.
3 REPLIES 3
jfhalaby
in reply to: john.higgins
Hi John,
Did you ever find out what was causing this message?  I am getting the same message except "From: Revit 2017 (Pre-release) To: Revit 2017" whenever I audit my model.
Jason
john.higgins
in reply to: jfhalaby
Hi Jason,
This is the reply I received from Autodesk support:
Hi John,
That's right, that's exactly the message we have seen before. I asked the developer who worked on this case to give me an explanation that I could pass on to you and to other customers who may encounter this issue, and here's what he said:
"There is some orphaned data in the model for which Revit has created a container. As this data is not in Revit's data dictionary it will throw an upgrade dialog on Audit as Revit ensures the model will continue to operate correctly. This orphaned data will not be used during an interactive Revit session and should not have any negative effects on the model health."
I hope this will give you some peace of mind; please feel free to pass it on to anyone in your company who is concerned about it.
I created this article to document the issue for you and other customers, and just updated it with the explanation above; if you don't see those lines at first, please try again in an hour or so. It may take a little time for the updated article to make its way through our systems to the public.
Please let me know if that answers your questions; I'll wait to close the case until I hear from you about this. Thank you again, and I'll be looking forward to hearing from you soon.
This is a link they also sent me:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Hope this helps,
John
jfhalaby
Thanks John,
Interesting, glad to know I don't have to worry about it.
-Jason
