Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Updating to Revit 2024
6 REPLIES 6
brianCB5NH
527 Views, 6 Replies
I updated to the Revit 2024 version recently and now all my cloud based work is gone. All the links in the Revit main home screen are gone. When I went to the online link and downloaded the source file and opened it up, A LOT of work is not there. Is all that work gone now?
6 REPLIES 6
RSomppi2
in reply to: brianCB5NH
Cloud projects are version specific. Have you tried opening it with the previous version that you were using?
brianCB5NH
in reply to: RSomppi2
Thanks. But now Revit 2022 only opens as a "viewer mode". Is it possible to copy over work or open as a regular version of Revit?
RSomppi2
You can upgrade the project in the cloud if that's what you really wanted to do.
brianCB5NH
Thanks. I believe only the admins can do that, correct?
RSomppi2
Not sure but it would make sense that permission to upgrade limited to certain people.
Are you sure that is what is required for the project?
brianCB5NH
No. I will keep it in the 2022 version. I read that as I was searching for a solution. Thank you for your help.
