Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Update a changed link, Survey Point stays, Project Base Point and project move
0 REPLIES 0
Message 1 of 1
peterpetschek
475 Views, 0 Replies
I work with the workflow C3D - Bim 360 - Revit (Version 2020.2).
I use Swiss coordinates like 2000000.000 (Easting), 1000000.000 (Northing). 7 digits before and three behind.
1. In C3D topography is published to the cloud as projectxyz-1.shared.dwg
2. In Revit I use the workflow described at AS321319, Cross-Discipline Coordination:
Civil 3D to Revit and Back Again with
ACQURIE COORDINATES and moved Survey Point to the correct location, etc.  Everything works fine.
3. In C3D I  change something in the topography and publish to the cloud again as projectxyz-1.shared.dwg.
4. As soon I open Revit it updates the topography the Suvery Point is still at the correct location, but the Project Point and the Project moved to a location double 4 000 000.00 (Easting), 2 000 000.00 (Northing).
5. When I use a new name like projectxyz-2.shared.dwg no problems exit.
What is wrong? What do i do wrong?
0 REPLIES 0
