Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Transfer Material Shared Parameter using Material Library
1 REPLY 1
Rubens1234
315 Views, 1 Reply
Hello everyone!
I've created a Material X with shared parameters in Project 1. Then, I've added it to Material List 1.
Then I created a new project named Project 2 and created the necessary shared parameters in that project as well (the same used in Material X).
Afterwards I've opened the Material List 1 in Project 2. Then I imported Material X from Material List 1 into the Project 2.
The problem is that the shared parameters that I've added to Material X in Project 1 and that was exported to Material List 1 doesn't appeared (i.e. don't transferred the values/text) in the Project 2.
What I want to ask is: Are materials' shared parameters transferred between projects using the Material Library? Or it is only possible to export the "native" information of materials?
Thanks!
1 REPLY 1
Hi!,
You´ve tried with transfer Project Standards? also put your shared parameters.
I hope help you
Regrats
Diana
