Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
There is no A360 folder when I go to open my project in Revit
6 REPLIES 6
282 Views, 6 Replies
When I opened Revit this morning there was no A360 folder. See attached image. How do I get to the A360 folder?
6 REPLIES 6
kmfuhrman
Hi, I'm going to ask the obvious...first, are you signed into A360 in Revit, and second, did you try restarting Revit? It should show up regardless, but maybe one of those helps?
Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
in reply to: kmfuhrman
Thanks Kimberly,
Yes, I am signed in and restarted Revit.
kmfuhrman
If you right-click in the "favorites" list, and click "Restore Standard Folders" does it return?
MichaelBussiere2
Thank you for your post.  In addition to Kimberley’s comments (thank you) If this is something that happened all of a sudden, a simple repair and restart of the system may help.  Please trey this and let us know how this worked out and how we can help.  Thank you and we look forward to your reply update.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
in reply to: MichaelBussiere2
Sorry, None of these fix the issue
MichaelBussiere2
Thank you for your reply.  In this case, can you identify a change on the system that is contributing to this ill behavior (IE a windows update or change to the PC itself)?  What operating system are you running the product on please?  Please keep us posted so we can best help wherever applicable.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
