Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
start up error Revit 2017 collaboration error
3 REPLIES 3
gtsstar
285 Views, 3 Replies
see attached picture
3 REPLIES 3
Revit_Whisperer
in reply to: gtsstar
gtsstar
in reply to: Revit_Whisperer
No no good tried it , its for revit 2015 not Revit 2017which is pre cloud !!
s180763
Same error here. I'm quite sure it is due to an upgrade; the Autodesk support team wasn't able to figure it out, and suggest me to ask here in the forum.
I think that it should be fixed with a downgrade.
I had the 2017 and upgrade to 2017.3 then the error started appearing, here is my installation info:
Build:
17.0.503.0
20161205_1400(x64)
2017.0.3
 Is it possible to downgrade it? Or  should I just uninstall and install everything again?
Did you solve the issue?
Thank you
Vito
