Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Spliting walls
2 REPLIES 2
A_MAQ
293 Views, 2 Replies
Spliting walls
when I was trying to split wall that is filled with different parameters , it's splitted to two walls but one of them does not contains any parameters
what is the problem ?
and if I try that on duct it preserve all parameters on the two segments
best,
Autodesk Expert Elite
2 REPLIES 2
laurasmagin
in reply to: A_MAQ
Is this a stacked wall or a simple wall you are splitting using the split tool?
If it is a stacked wall, check if the two walls are the same type.
If the parameters are instance parameters then they may be lost, and default to blank.
Hope this helps
Give me Kudos or mark as a solution if this helps
Regards
Laura
A_MAQ
in reply to: laurasmagin
the solution is
revit preserve data for duct and pipe once splitted , but for the other elements will not preserve data
