Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Spliting walls
2 REPLIES 2
A_MAQ
317 Views, 2 Replies
Spliting walls
when I was trying to split wall that is filled with different parameters , it's splitted to two walls but one of them does not contains any parameters
what is the problem ?
and if I try that on duct it preserve all parameters on the two segments
best,
Autodesk Expert Elite
2 REPLIES 2
in reply to: A_MAQ
Is this a stacked wall or a simple wall you are splitting using the split tool?
If it is a stacked wall, check if the two walls are the same type.
If the parameters are instance parameters then they may be lost, and default to blank.
Hope this helps
A_MAQ
the solution is
revit preserve data for duct and pipe once splitted , but for the other elements will not preserve data
Technology Administrators
