Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Shortcuts Revit 2017 don't work
1 REPLY 1
TM1995
346 Views, 1 Reply
My shortcuts in Revit 2017 don't work. But the crtl commands, for example ctrl + c and ctrl + v, do work. In other programs such as MS Word all the keys work as usually.  The other commands only work when I click on the buttons in the ribbon at the top of Revit.
I have tried to solve the problem with the following things:
- Imported the standard keyboard shortcuts of Revit 2017
- Deinstalled all Revit programs and reinstalled Revit 2017 with the standard settings
- Connected a external keyboard
- Installed the latest keyboard driver
The problem is, when someone else controls my computer with TeamViewer, de shortcuts do work. Only at my computer the shortcuts won't work.
Does anyone know how to solve this issue?
1 REPLY 1
robert.klempau
in reply to: TM1995
Hello @TM1995,
If you hold the Alt key down, do you see the shortcuts on top of the buttons like you see in te picture below?
And when you open the Keyboard Settings dialog box, do you see the shortcuts there?
Did you try to install Revit update 2017.1?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
