Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Shared coordinates and the rule of 20
1 REPLY 1
sife
233 Views, 1 Reply
Hello
I hava heard and read alot of issue about if object is far away from some of the point in Revit.
Is this still and issue and is it only project base point and not survey point or is it both or how is it?
1 REPLY 1
GustavoPardo
in reply to: sife
I believe it does, still after reaching the max distance  gives you the warning . Most of the time, this issue happens with our landscape or civil files. Our procedure is as follow before we start generating geometry  :
Open cad and get the survey point
Open Revit and relocate Survey point to the same location
Insert CAD
Share coordinates with other parties
Good luck
