Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Screening tag information for existing
1 REPLY 1
peter.clayton25KEVV
182 Views, 1 Reply
Looking for solution to screen tags for use when tagging existing information in model.
1 REPLY 1
The question is a bit ambiguous, I am assuming you are looking for a way to distinguish between tags for existing elements verse tag for new elements.
Firstly you need to ensure the elements are correctly set by phases.
You can then tag elements using tag all by filtering elements in a phase. I would suggest you have tags that look differ rent for each phase to distinguish on the drawing sheets.
Hope this helps
Give me Kudos or mark as a solution if this helps
Regards
Laura
