Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Room tag
2 REPLIES 2
A_MAQ
380 Views, 2 Replies
Room tag
Hi all,
I am working in a elec file that has a linked arch file (which contains rooms)
when I try to tag the rooms in elec file it does not do that unless I set the link file to (by linked view)
what is the problem ?
best,
Autodesk Expert Elite
2 REPLIES 2
dzanta
in reply to: A_MAQ
you should be able to tag the room object within a linked revit file from a host file...this is a default.  make sure your room objects are visible in the view.  Use Visibility Graphics to turn on reference lines and shading first...
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
A_MAQ
in reply to: dzanta
thanks dzanta
it's solved by mapping the project phases
