Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
room tag issue
2 REPLIES 2
A_MAQ
348 Views, 2 Replies
room tag issue
Hi all,
in this room tag family once i upload it to project the border of room number remain appeared
how can i make the border of the room number hidden when loaded to project?
thanks
Autodesk Expert Elite
2 REPLIES 2
laurasmagin
in reply to: A_MAQ
use VV or VG to turn on the annotation categories, you'll find the line work is turn off.
Select the lines and delete them to get the result your after, with a room label with no boarder.
Hope this helps
Give me Kudos or mark as a solution if this helps
Regards
Laura
A_MAQ
in reply to: A_MAQ
It is solved by mapping the project phases
