Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
REVIT verses REVIT LT
6 REPLIES 6
ken_pysmeny
776 Views, 6 Replies
I would like to know what are the differences between REVIT and REVIT LT. What can I not do with REVIT LT that I can with REVIT.
Ken Pysmeny
6 REPLIES 6
ryan.duell
in reply to: ken_pysmeny
I have included a link which outlines the differences between Revit and Revit LT:
http://www.autodesk.com/products/revit-family/compare/compare-revit-products
Hope this helps, thanks!
Ryan Duell
harlan_brumm
Thanks for your question!  You can see a full list of differences on our website here: http://www.autodesk.com/products/revit-family/compare/compare-revit-products.
At a basic level the most significant difference is the lack of support for worksharing with Revit LT.  Also, Revit LT does not have rendering in the product but uses Rendering in the cloud.  Finally, Revit LT does not contain any MEP functionality and has limited Structure functionality as well.
Hope this helps.
Harlan Brumm
Sr Product Line Manager, Core Capabilities and Collaboration Services
mpwuzhere
Hi Ken,
A full list is here: http://www.autodesk.com/products/revit-family/compare/compare-revit-products
But mainly Revit LT doesn't have MEP, Collaboration functionality, massing, and limited structural capabilities found in regular Revit.
laurent
It appears that LT simply has some reduced functionality.
Can an office run both Revit and Revit LT?  Can one person start a design in LT and another continue in Revit (or the other way around)?
thank you,
Laurent
ryan.duell
in reply to: laurent
Yes to both - an office can have a mixed Revit \ Revit LT environment.  And you can open models in either - some additional details on worksharing models in LT:
http://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit...
Ryan Duell
laurent
in reply to: ryan.duell
Thank you!
