Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit to IFC using IFC2x3 Extended FM HandOver View for COBie
1 REPLY 1
Mark.T
1294 Views, 1 Reply
Hi all,
I'm attempting to align IFC mapping out of Revit to align with NBIMS Annex A COBie mapping rules and using the COBie extension for Revit parameters. I've updated the standard IFC2x3 Extended FM HandOver View.txt file to add a couple of additional parameters. However it won't seem to export the instance parameters in the Revit project to the IFC/property sets.
Does anyone have an idea why this might not be? I attach some images of the mapping table, Revit instance parameter view and Solibri Info tab.
Any assistance would be greatly appreciated. Many thanks in advance.
Mark
1 REPLY 1
aleksei.tkachenko
in reply to: Mark.T
Have you tried to change "ifcElement" to "IfcDoor" and see if it works  for doors only? In my case I had to list all elements in mapping file instead of using ifcElement in order to make it work.
